How do I find my driveshafts u-joint angles???
Discussion in 'The Garage' started by morcav, Mar 30, 2007.
  1. morcav
    morcav Registered Member
    Oct 2, 2006
    89
    Where the Army tells me to!
    I have been getting some really bad vibes coming from my shaft, and need to figure out how to correct them asap. What I've gathered so far is that I need to shim my rear diff, but how do I find out what degree shims to use? Everything (driveshaft, axles) is stock exept a 4" lift with blocks in the rear and 35's. Going to a 4 wheel drive shop or a driveline shop is out of the question being that I'm stationed in Germany right now. Any help is greatly appreciated.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You can just get some 3 degree shims and stick them in and you should be ok. Some need them with a 4" lift, some don't.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Read this: driveline 101
    Pretty much Everything you need to know is covered there.
    You can get an angle finder from most any hardware store (even in Germany). I bought mine from Ace for about 10 bucks.
  4. morcav
    Oct 2, 2006
    89
    thanks alot guys!!!!
