how do i fix this???????
Discussion in 'The Garage' started by morcav, Dec 14, 2006.
  1. morcav
    morcav Registered Member
    Oct 2, 2006
    89
    Where the Army tells me to!
    I have a vibration when driving down the road, mainly when I am starting to press on the accelerator or letting off, I'm thinkn that it is my driveline or pinion angle, and if your answer is shims then how do I know what degree shims to order? I appreciate any help/info
    91 K5, 4" lift w/blocks inthe back and 35" m/t's
  2. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    Also check that your U-Joints are good.
    To check angles, you need to measure the angle of the yoke coming out of the case, and the angle of the pinion. Thease measurements are taken in reference to level ground. You want the two to be at less then a 5* difference
  3. morcav
    Oct 2, 2006
    89
    what all would I have to do to drop the t-case?
