How do I flush my cooling system??
Discussion in '1982-Present GM Diesel' started by 84CUCV, Dec 2, 2002.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    The shop near me wants 75 to do it. Is that a good price? Sounds like a bit much to me. So how do I go about this? Thanks Mike
  2. BanksBurban
    BanksBurban Registered Member
    Mar 23, 2002
    88
    New Jersey
    On anything, I pop the thermostat and the lower hose. Run a garden hose through the radiator and block until nothing but clear water runs out. Install a new t-stat and re-attach the lower hose. Then fill with straight, uncut antifreeze until it's full and I almost always end up with a 50/50 mixture because of the amount of water still in the block from flushing.
    Most of those "mailer coupons" and ads for a cooling system flush, they drain the radiator and fill it with up to 2 gallons of new a/f. Doesn't sound much like a flush to me. That's why I do my own.
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    You can buy a flush kit at any auto parts store for around $6.00. Might not work quite as well. If your not having problems overheating, id just do it yourself.
  4. 86DIESEL
    86DIESEL Registered Member
    Apr 21, 2002
    34
    South Carolina
    when using the kits from the auto parts stores I found that a water supply line for a washing machine works alot better than the double female adapter that is used between the water hose and the "T" that you install in the heater line. I unhook the bottom radiator hose to drain the system as well. the plastic thing in the kit that goes on the radiator works better with a long piece of hose stuck in it so you can control where the flushed coolant dumps if you choose to use it. I just flushed and changed the coolant in my truck's system over the weekend.
  5. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    You might want to check exactly what the shops flush entails. I brought in my car to get done because they have this new fandagled machine that pumps it clean, and I mean clean with some sort of scaling remover. It doesn't just change out for cleaner fluid it removes the build-up pretty good. I've never got the home kit to work that good. If you just want an exchange for cleaner fluid, then by all means DIY.
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks for the help guys!! Mike
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I used to flush mine without the kit, and now that I used it it does make a difference, it goes into the heater core, back to the engine so it does flush the whole system and after a couple of weeks the coolant is still clean.
    Without it I used to have rust back in one day.
    Just run the flushing fluid in the system for half an hour then dump it and back flush with the kit, you won't believe what comes out.
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    What kind of kit was it? thanks Mike
  9. 86DIESEL
    Apr 21, 2002
    34
    South Carolina
    The kit I use looks just like this kit.
  10. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Same one I used by Prestone.
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks a lot guys. I will be doing it soon. Mike
