How do i get forn drive shaft off?
Discussion in 'The Garage' started by dodgetruck91, May 22, 2003.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    Im pulling my tranny, and i cant get the front drive seperated form the X case, is there a trick to do this? i unbolted the 4 bolts by the flange near the x cas and it did nothing. thanks, jon
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Crowbar????
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    do you own a hammer?
  4. Confedneck
    Nov 1, 2002
    5,236
    hammer much? and some penetrating oil
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just take it loose from the front and wrap something around the U-joint to keep the caps on. The shaft will still hang from the T-case but at least you can move it
    My $0.02
  6. dodgetruck91
    Oct 22, 2002
    99
    ok, i just didnt know if that was the right spot to remove it from the x case. the problome is im putting a new trans and x case in and i need to reuse the shaft, otherweise i wouldnt of cared.
