How do I get the armrests off?*Problem Solved*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by marine_enlisted, Apr 27, 2003.
  1. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    1991 Sub. I'm trying to take the front buckets apart to wash the seat covers and I can't figure out how to get the armrests off. /forums/images/graemlins/angryfire.gif All I can see in there is a screw that adjusts how for down they go. Anyone had them off before? /forums/images/graemlins/usaflag.gif
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Re: How do I get the armrests off?
    There should be a zipper or velcro on the bottom, undo it and pull the cover off the outside enough that you can see the screw. There should be a torx or an allen head screw that holds the armrest to the seat back. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Hope that helps, it not shoot me a line and I can give you some other suggestions.
  3. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
    These have no zippers or velcro anywhere on the seats. Just hog-rings at the bottom. What else do you suggest? /forums/images/graemlins/usaflag.gif
  4. Grim-Reaper
    7,385
    Atlanta
    I'm having same issue with my 88 Sub. Did you find any armrest pads BTW?
    TOP
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    if you dont have a zipper or anything, try tugging on them a little? did you try taking that adjuster screw off to see what happened? just tryin to throw ideas at ya /forums/images/graemlins/thumb.gif
  6. marine_enlisted
    Sep 29, 2002
    658
    Stafford, VA
    Figured it out! You have to work the cover back a ways then there is a 3/4" pivot bolt that holds the armrest to the seat frame. /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
