How do I get the dipstick back in?
Discussion in 'The Garage' started by txbartman, Oct 9, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Okay, got the new motor installed in the truck. One problem, I forgot to put the dipstick in the block before putting it back in the rig. /forums/images/graemlins/ears.gif Any recommendations for the easiest/best way to press the dipstick back into the block with it mounted in the rig?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Lightly tap the end with a hammer. It should slide in. I also put a dab of silicon on the end to help it seal.
  3. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    Ho do you lightly tap on a curved end?
  4. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    i have used a rubber mallet or dead blow hammer, and put some silicone on it to help slide and seal once it is seated, just hold it in place at the position you want and lightly tap it in, if it has a lip around where it seats in the block you can tap on it with a chisel or punch to set it once it gets seated
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    You didnt say it was curved. The ones I had were all strait. If you cant get it by twisting and pushing I dont know what to tell you. Maybe go buy a chrome strait one from the parts store. A few $'s.
  6. GMslave
    GMslave 1/2 ton status
    Oct 3, 2002
    113
    Flint, Michigan
    Try and slide a bolt down the tube so that the head covers the tube when seated,then tap on that. That way you won't distort the end if you want to give a little more persuasion. BTW, I LMAO seeing your post just in front of the "i gotta ? about women". I gotta grow up......
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    There should be a collar (bulged metal ring) on the dipstick down where it goes into the block. I use a piece of brass (hard but softer than the dipstick metal) and place an edge agaist the collar and hit the brass with a hammer, hitting a different spot each time, this drives the dipstick in with minimal marking of the dipstick surface.
  8. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    If it has the buldge Leadfoot was describing, put a 1/2" (I think that is the right size) open end wrench above it but resting on it. Tap on the wrench "teeth" with a hammer.
  9. Leadfoot
    Nov 28, 2000
    3,112
    alec78: That sounds like a good way to do it. I will have to give it a try next time.
  10. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    I was thinkin the same thing..... That question sounds kinda personal for a 4x4 webpage. lol. /forums/images/graemlins/1zhelp.gif
