how do I get the hub separeted from the drum on a 14ff???
Discussion in 'The Garage' started by Supreme70, Mar 13, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I have the drum off and the hub wont come off, I have already pounded out the studs, but it still will not come apart should I put the drum on some wood and try to beat the hub out? What about alittle heat? Help!!!!
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    put it on some wood and beat the hub out.
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    And put a block of wood on the hub when you are hitting it. You don't want to mangle your hub. At least if you plan to use it again.:laugh:
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I'd lay a hurtin on the drum itself...smack all around the hub and the hub should eventually drop out.
    Rene
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yep..
    Put a small block of wood under the whole set up, with the drum wheel mounting surface, pointed up. The back of the hub, where the dust seal is, should be sitting on the block, and the drum should be OFF the floor. The block will need to be smaller than the diameter of the drum, so that the drum has space/room to travel down.
    Now, beat the buh-jeezers out of the drum with a shop hammer of your choice... don't stop until the drum is ON the floor. :D
    If it still does not want to seperate all the way .. add too, or get a taller block.
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    take all your frustrations out on it... give it a world o hurtin....
    lucky for me mine popped out with minimal effort :cool1:
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I always enjoy a project when "Hit it with the BFH" is the answer.
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Give it a Donkey Punch!
  9. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    LOL, since the drum turns into a bell .. and makes one helluva racket .. it's a good time to let off any steam..
    mother "CLANG" er .... you dirty rotten son of a "CLANG" ... "CLANG" you, you "CLANG" ing piece of "CLANG"...
    :haha:
  10. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Get out the 20 lb. Ford wrench and go after it.
