How do I get the most flex with a 4" lift?
Discussion in 'The Garage' started by franco802, Dec 14, 2006.
  1. franco802
    franco802 1/2 ton status
    Oct 16, 2004
    270
    San Diego, CA
    I was going to do 33" tires, 4" rough country springs/shocks up front and ORD 4" shackles for the rear and a 1" block(rear only) to fix the rear sag.
    This sound about right?
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    Yep, but get a zero rate add a leaf instead of a normal block.
    And assuming you mean a ORD shackle flip, not longer shackles.
  3. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    I would go with Tuff country or BDS springs if you want flex.
    Dan
  4. dhcomp
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    Theres some chart around here with all the spring flex rates.....but i have no idea where it is.
  5. franco802
    Oct 16, 2004
    270
    San Diego, CA
    Yes, that's what I mean:D
    Also, a zero rate is not a leaf right? It looks like a skinny block? I have never seen one before.
  6. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
  7. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
  8. franco802
    Oct 16, 2004
    270
    San Diego, CA
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    To get the most flex out of any suspension you will have to remove the limiting factors. In front find some ford shock towers make sure your brake lines are long enough and remove your swaybar. In the rear once again make sure brake lines are long enough and the shocks are the right length. I have never had a lifted truck where I left the rear shocks alone so I don't know if they limit or not.
