how do i get the pinion out?
Discussion in 'The Garage' started by big83chevy4x4, Jun 17, 2004.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im changing the bearings in my dads 7.625 rear end in his safari minivan. i have the carrier out, pinion nut off and yoke off. the pinion seems to be stuck, doesn't look to be a snapring in there. what could it be? /forums/images/graemlins/1zhelp.gif
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    i dont know if it will work bt maybe TAP it with a hammer and see if it moves.
    nick
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    tried that, doesn't seem to change. it has a little play in it. its almost like the front most bearing is stuck on the pinion, the inner race moves with the pinion /forums/images/graemlins/dunno.gif
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ok i put the old nut on it and gave it some love from the persuasion stick, and she finely poped off. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif
    got another question, when i took the carrier off, there was only 1 shim. 1 in one side and none in the other, at least i can find. its almost 3/16" thick. i always thought that there were shims in both sides. /forums/images/graemlins/dunno.gif
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thats not good, if the inner racefalls out of the housing, maybe you need a new housing.
    I get them out with a brass punch on the pinion and beat it out.
    It might have shims behind the carrier bearing on one side.
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    thatsnot good, if the inner racefalls out of the housing, maybe you need a new housing.
    not the race that is press into the housing (outer race), the one on the pinion, the part with the cage and all the rollers (inner race)
