how do I get the steering box off?HELP ASAP!!
Discussion in 'The Garage' started by 84gmcjimmy, Dec 4, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I unbolted 4 bolts that hold it to the frame, but then there is an arm that goes to a rod, the to the wheel. How can I get this apart? I don't see how to. I unbolted a bolt at the bottom of the steering box where the arm is, but that must be pressure fitted on becauyse it won't move. It looks like I am mangaling the rubber part and maybe other stuff where the grease nipples are underneath. HELP ASAP so I can finish for the day and come inside!
  2. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    /forums/images/graemlins/confused.gif If I'm reading you right everything is unhooked except for where the steering box connects to the steering wheel right? There should be just 2 bolts to undo right where the funny round rubber thing is. (?ragjoint?) That should be it man /forums/images/graemlins/dunno.gif
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if you take claming bolt off the steering box, oyu need a pitman arm puller. or you can take the draglink off (bar that goes to the steering arm on the knuckle) and use a tierod seperator, looks like a tapered tuning fork, to get that off. you may beable to use a big pry bar to get the drag link from the pitman arm (arm on the steering box)
  4. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    nevermind it sounds like your talking about the pitman arm. if thats the case take the bolt you undid out and just bang it off with a hammer.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    ah sounds like I need special tools /forums/images/graemlins/doah.gif
    I will try to bang it off with a hammer...
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I never realized how heavy the steering box is /forums/images/graemlins/yikes.gif
    I tried to rebolt it back to the frame so I could knock off the arm that attaches to it. No way, that didn't happen. I gave up and went into the shop and sat. Then came inside.
    I was SOOOOOOOOOOOOOOOOOOOO frustrated /forums/images/graemlins/angryfire.gif
    I will try again tomorrow I guess
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Steve what are you trying to do? You can always just remove the drag link at the knuckle, might be easier than bolting the box back up. Have someone hold a large pry bar under the ball joint on the steering arm end in an upward pressure. Then after the nut is removed, tap the side of the round metal surrounding the ball joint w/ a hammer. It should pop right off and you will be able to remove you box away from the vehicle /forums/images/graemlins/waytogo.gif
  8. offroadcowboy
    offroadcowboy 1/2 ton status
    Jan 29, 2004
    171
    Wittman,Arizona
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif I just did this two days ago. I was gonna just he man it up under there with one hand and put the bolts in with the other /forums/images/graemlins/whistling.gif so about 10 minutes of that and i went and got someone to help me. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  9. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    What does one of them there steerin boxes weigh?
  10. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    When I bought a new steering box the shipping weight was listed at 30 pounds.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    About 5 lbs more than you want to drop on your fingers. /forums/images/graemlins/rotfl.gif
  12. RustBuket
    Feb 21, 2003
    1,618
    hahaha, Well thats true. You should be albe to do a 30lb one arm lift. I spose its probably in some awkward as heck position and hard as heck to hold. That always happens to me.
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    30 pounds sounds close /forums/images/graemlins/thumb.gif
    I don't know how to explain it, because I don't know anything about steering parts. But I unbolted it from the frame like I said, then underneath the steering box, there was a arm of some sort (pitman arm???) that connected to the steering box on one end, then on the other end there was a bolt sticking up, with a nut, and a cotter pin through it that was connect to a short round rod, that connect to a "C" sort of shaped thing on the axle (steering knuckle?) I will see if I have a pic...
    I unscrewed 3 nuts that (what I thought) connected the "C" shaped thing to the axle (steering knuckle????) and tried to take it off from there, and that didn't move!
    Then I tried to unbolt the nut, bolt part, and cotter pin that connected to the (pitman arm???) and the round rod. That that didn't do much. So then I tried the (pitman arm) where it connected to the steering box, I unbolted the bolt that clamped the arm onto the steering box, and tried to hammer it off. Didn't move /forums/images/graemlins/dunno.gif
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I can lift it up with 1 arm, but it's awkward as heck, and it's still connected to a bunch of things, so when I go to move it, it yanks around, and I can't get it flush against the frame to re-bolt it up. I dropped it on my thumb, wasn't to happy after that /forums/images/graemlins/yikes.gif
  15. RustBuket
    Feb 21, 2003
    1,618
    I hear taking off a steering arm "round c thing" is a b****. They get seized on there like you wouldn't belive. You'd have better luck taking the "round rod" (drag link I think) off the steering arm with the correct tool or the pitman arm off the steering box with a puller.
  16. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have never had any problems. Maybe people swing their hammers like girls?
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    So either way, my best bet is to rent a puller/tool?
  18. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Steve..
    Buy a pickle fork and stop screwing around.
    I just took one off 2 days ago and had it off in under 5 minutes.
    Don't try to remove the pitman arm or the steering arm.
    Just pop the pitman arm off the draglink and be done.
    Smacking the draglink socket a few times will usualy pop em out. Although it helps to have the box mounted on the frame.
    I would start with that.
    Jack up the front(chock the rear) till the wheels clear the ground, that should make manuvering the box back into position easier.
    2 people would make that task easier.
    You can buy a set of forks with interchangeable heads for $30 or so.
    I have a few for my IR air hammer that work pretty slick.
    The right tools for the job make it alot less frustrating.
    So ya spend some coin for a tool, you will use it again.
    I wrench for a living and will spend $80 on a socket that I will proly only use once a year in a heartbeat if it makes the job easier.
    Hang in there it's almost out. At least it aint a 120lb gearbox with 5 1" bolts that ya are trying to start. /forums/images/graemlins/screwy.gif
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I tried to rent a set today, I don't have 30 bucks to spend right now...
    They didn't have it, they have tie rod and ball joint pullers, what one will work?
    Thanks for the help!
  20. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    anyone know?
