How do I get the stock steering arm off???
Discussion in 'The Garage' started by korndog, May 13, 2005.
  1. korndog
    korndog Registered Member
    May 7, 2005
    13
    California
    I got the draglink ball joint off, I have taken the three nuts off the studs. How Do I get the steering arm off now?? Please help I am in the middle of putting my new lift on.. Oh yah it's on a 1984 chevy suburban 3/4 ton 4wd.
    Thank you in advance...
    Kory
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Did a search in the garage there are a few but try this one.
    CLICKY HERE!!!
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Your not in the rustbelt , just hit it a few times with a big hammer and it should come off :D
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    PB Blaster..BFH...PB Blaster...BFH... :D
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If you have a gear puller available they work great too. My assembly was rusted solid so the BFH method wasn't even enough.
  6. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    Remove the 3 bolts holding the arm. There will be 3 cone-shaped washers that need to be removed. I had luck getting them off on my 10bolt, but they wouldn't buge on the D44. I smacked it with a BFH a couple of times until the cones stuck out enough that I was able to unloosen them. Do a search, I remember there being several threads with tricks on how to remove these.
    Good luck :grin:
  7. black'burb
    black'burb 1/2 ton status
    Mar 11, 2005
    182
    Northeast WA
    I just dealt with that pain a week ago when I put a 4"lift on my '91 3/4 Sub.
    PB and a sledge. Just don't smack the fender trim to pieces when wailin on it. Hope you're replacing the arm...
  8. korndog
    May 7, 2005
    13
    California
    OK I got the BFH but what are you talking about with the PB????
  9. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    PB blaster ''yellow can'' like liquid wrench but better.
  10. black'burb
    Mar 11, 2005
    182
    Northeast WA
    The stuff works really well...Probably the only thing that does with a "As seen on TV" on the label. Any parts store should carry it. Use liberally and go to town with the BFH. When you see the cone washers start to pop up, smile, you're almost there....
