How do i get the stupid ignition lock cylinder out?
Discussion in 'The Garage' started by y5mgisi, Sep 2, 2004.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Man i can not get it figured out! /forums/images/graemlins/mad.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    pull the wheel, the lock plate and the signal assembly, on the older trucks there is a small flat tab about 1/2" long that needs to be pushed down while pulling the lock cylinder out. one nice thing about the older ones is you can put it all together and then just slide the lock in there.
    the new ones have a small bolt hold it in.
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Ok i have the old style one then casue it does not have a bolt so where is the tab and what does it look like.? /forums/images/graemlins/confused.gif
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its near the rear of the cylinder, it goes perpendicular to the cylinder. actually all you see is a slot, push something in the slot and pull it out.
  5. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    is the slot like a 1/16th by 1/2" or so?
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
  7. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    hmm wiered ok i'll go try that and be back in about 5 minets to tell if it worked or not /forums/images/graemlins/thumb.gif
  8. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    did you get out? Mine (85) had a screw. BTW, i believe you should have it in the 'on' position to get it out (not to be confused with start) to turn the cylindar. Its a saftey deal, so u have to have the key in to do a swap (theoretically making it hard to steal our gems) Hope it helps. I think my 78 had to be 'on' to get the pin to pop out so i could grab it with plyers.
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i changed the lock on our old 78 cause it didn't have a key, it had the tab not the screw.
  10. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Well that did it! thanks soooo much for your help! To bad i lost the bearing that suports the shaft closest to the wheel in doing all this /forums/images/graemlins/mad.gif So i'll have to do some calling around tommorow to find that(yah good luck right) Any who thanks and thanks again for your help!
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    np thats what we're here for.
    is it a tilt column? if so i have a culumn here i can get the numbers off of for you.
  12. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i pulled mine out and the balls went everywhere and there are no numbers on it that i seen.
    you might have to go to the dealer to get one.
  13. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    bummer thanks for tryin though
  14. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    my lock cylinder is meesed up and my tilt column is LOOSE so I have a new tilt wheel with key I'm putting in /forums/images/graemlins/tongue.gif
  15. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    You can get a ignition rack kit at the dealer. Its not too much money. Comes with the rack, both the bearings for the tilt bowl, the spring and the little plastic thingy that meshes with the rack. I'll look around for my invoice if you'd like.
