how do i get this off?
Discussion in 'The Garage' started by obijuan, Aug 26, 2006.
  1. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    this ring in the back? ive got to replace my lug nut studs. is there a better way?
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    hub socket. good auto parts place should have one.
    j
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    That should just slide out. Use a magnet and a pick.
  4. obijuan
    May 18, 2006
    4,009
    San Antonio TX
    whats an alternative way?
  5. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Coat hanger with about 1/8" 90 at the tip. Paper clip and needle nose, two long skinny screwdrivers....
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Needle nose pliers.
  7. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I use snap ring pliers. just grab it like a snap ring in two holes and pull'er out!
  8. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    This sounds like a joke I know ... the punchline to which "so you can carry them like a sixpack" ... cough...
    -- A
  9. RaisedK5
    932
    Long Beach, CA
    :haha: :waytogo:
  10. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    x2 for me works perfect:D best to grab at the point of the tab so it pulls stright out.
  11. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,961
    251
    Released from Pueblo, told I belong in Southpark
    The washer with holes in it slides straight out. If you aren't familiar with it there is a small post on the front of the hub nut that sits in one of the holes so you need to get behind it with like a seal pick or screwdriver with a bend at the end. 2 of them works well and then you can get one behind on each side and jockey it out. Then hub socket on the nut after that.
    In the pic it almost looks like wire around one of the tabs but I suppose it is just marks from attempts to remove it.
