How do I go about
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James, Jan 15, 2001.
  1. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    finding the problem as to why my k5 pulls from side to side. Is this just the way it is with 33's(large tires). Have new steering stabilizer. New power steering pump. Whenever on unlevel road (paved) my k5 tracks to whatever way the road is banked. Especially when breaking just finds the ruts in the road and pulls massively. It has always done this to the point you have to fight with the sterring to keep in your lane. Just figure its time to correct or is this normal. Its definetly not my breaking system as every part from rotors, drum, calipers, and bearings are all new(less than 7.000 thousand miles). I'm thinking worn ball joints. Though no vibration in truck at all. How do you identify worn ball joints and how hard to replace??? Or whatelse could cause this? schocks? Fairly new tires and recently balanced and alligned. Need help
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    It sounds like a Bias ply tire....... When I had my MT Baja, it did the samething.....Radial tires end up not pathing on the road as much....
    C'moe
    <font color=black>the blazer is "Back in Black"
  3. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    James, My '91 did the same thing when I bought it. The previous owner had replaced ball joints, rod ends, tires, etc and didn't fix it. I read about the ORD Steering Brace on this forum and for $100 and a couple of hours work it fixed the problem. Check the ball joints first by jacking up a wheel and shaking the wheel, in-out, up-down, left-right to see if there is excess looseness. Fix that first if it is loose. If tight, make sure the steering box is bolted tight to the frame and no cracks in the frame. If OK, install the brace. It will prevent excessive frame flexure and that will tighten up the steering.
    You can come see mine if you are interested. I live in Santa Monica.
  4. James
    Jun 22, 2000
    179
    Castaic, Ca
    Yes. I am riding on 33x 14.50 MT baja belted. Definatley the most overpriced piece of sh!ts tires I every bought. But my truck even did this with my last radials I had??? Will be getting some BFG's soon. Maybe third time will be the charm??
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would follow toms advice and check everything out and also order the ord brace also check to see if the frame is cracked behind the steering box
    s.smith 77blazer lookin 4 mud
  6. James
    Jun 22, 2000
    179
    Castaic, Ca
    Cool,
    I'll start there. Was thinking maybe 2 steering stabelizers might help??? Yah If you ever plan on going to Castaic lake. Drop me an email. Fun part of town of the weekend. Lots bikinis and T-backs. Plenty romm on the boats.
    Peace
    Jay
  7. CK5
    May 19, 1999
    21,623
    701
    CO
    Mine did the same thing, I installed the ORD steering brace and that fixed at least 75 percent of the wondering on the road, I coulnt believe it made that big of a differance, I just put up the ORD review, check the main page or the product review section.
    Steve
    1990 K5 with stuff
  8. James
    Jun 22, 2000
    179
    Castaic, Ca
    ORD brace it is. As always. Muchas gracias amigos
    James
