How do I keep my distributor dry??
Discussion in 'The Garage' started by CAMAROBOY69, Oct 3, 2002.
  1. CAMAROBOY69
    CAMAROBOY69 Registered Member
    Aug 30, 2002
    33
    Muskegon, MI
    Does anyone have any secrets or tricks on how to keep the distributor dry on my mud truck?
    I dont have any problems with the carburetor at all because of the trick setup I have. I just need an some ideas on the distrubutor cap. Gotta keep the heat to the plugs /forums/images/graemlins/angryfire.gif /forums/images/graemlins/thumb.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Points or HEI?
  3. CAMAROBOY69
    Aug 30, 2002
    33
    Muskegon, MI
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thats a good question. I run mud and water most of the time and have never had a problem with my HEI. I know other people have put silicon on the base of the cap and this seals it. You have to vent the cap though when you do this or vapers will sooner or later build up and cause it to misfire.
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I'm not sure if it will fit an HEI distributor but on my MSD distributor I use the rubber boot/cover from a Ford V8 - works great, it completely covers the distributor.
  6. CAMAROBOY69
    Aug 30, 2002
    33
    Muskegon, MI
    nvrenuf
    How does that bolt/screw on? Sounds like an excellent idea. Do I just get that off of any v8 ford?
  7. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    It basically looks like a rubber diaper that is installed upside down over the distributor cap. It is held in place by hooks and holes that are molded into it. Mine came off of a mid 80's Crown Vic with a V8, if I'm not mistaken they were used a lot on both the Crown Vic's and mustangs in the 80's.
  8. CAMAROBOY69
    Aug 30, 2002
    33
    Muskegon, MI
    Great idea. Diaper here I come. /forums/images/graemlins/laugh.gif I will look in the junkyard this weekend for that. T/Y
    I used to cut out the bottom of a 2 liter and place it underneath the cap(like a diaper) and tape it with duct tape. Worked great and never got wet but was a lot of work and was a pain to get off when I wanted to check the cap. /forums/images/graemlins/thumb.gif /forums/images/graemlins/truck.gif
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    yep, i did the same thing, took mine off my '89 mustang gt, works perfect
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    That is a good idea. I'll have to look for one also. Thanks.
