how do i keep my truck from going into OD
Discussion in 'The Garage' started by bryguy00b, Apr 3, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ive heard its not such a good thing for a 700 to be going into OD a lot..and around town mine does it a lot when i get up to a certain RPM..how do i keep it fomr going into OD..
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Ummm, leave it in 3rd gear............. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i would assume that you are putting it in D and still feeling a fourth shift? if so its not over drive its T/C lockup. its perfectly normal, just annoying some times. you can get a kit from summit or jegs to turn it off or back to the normal way
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    not anoying at all..its just that when the 4 gear comes or what it feels like anyway, the engine rpm lowers down like its in OD or something...i thought maybe it was i dunno..ive never had a truck with a 700 befor..(at least that i could drive lol)
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Actually, if you have a lockup converter you have 5 speeds /forums/images/graemlins/thumb.gif Shifting into OD and lockup is normal operation. If you have big, oversized tires that bogs the vehicle down or climbing a long grade or are towing a heavy load and it keeps consistantly shifting in-n-out of overdrive, you can pull the shift lever down to "3" and it wont shift into OD or lockup. If just normal driving, let it go.
  6. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    any truck with a 700 R4 in it from 1986 is not going to have this pattern P R N (D) D 3 2 1, its going to have one like this P R N (D) D 2 1. if you have bigger than stock tires, or low numericaly(high physicaly) gears like 2.73, or 3.08's you should run in D most of the time any way. when you run a 700R4 at low speeds in OD then it isnt moving fast enough to move the fluid to cool it off.
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i have 3.08's and 31's and it only goes in overdrive when it gets to about 50 mph maybe?
