How do I know what gears I have
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Sep 6, 2000.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Hey guys I am sometime going to add 33s w/ 4" ORD Shackle Flip and new springs in the front, and I want to know what gears I have. How do I find out what I have? (easiest way besides look at piece of paper that came w/ rig). It is a complete stock 88, w/ 10 bolts, the rear end has been rebuilt w/ that if it has anything to do with it or would change any thing. What would be good to run 33s with?
    Thanks!
    Dawson
    88 K5
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I run as of today, 2.5 lift w/33's stock gears (3.08) and I have no problem's.I can reach 85 on the freeway,and can tow a horse trailer! In the future I want to get 3.73 or 4.11 (when I have $$$) I hope that kinda helps!
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Look at the RPO codes printed inside your glove box:
    GU2 = 2.73
    GU4 = 3.08
    GU6 = 3.42
    GT4 = 3.73
    GT5 or GT8 = 4.10
    G80 = Gov-lock locker
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  5. GMC4by4
    GMC4by4 Registered Member
    May 10, 2000
    48
    Silver Spring, MD
    There will be a number stamped in the top of your axle housing- it's in different places on different years and you may have to use a wire brush to be able to read it- take that # and call the local salvage yard. They'll be able to give you all the info on your gearing and posi or whatever you have.
    -Rick
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    One more way is to pull your covers and there will be a ratio stamped on your Ring gear. It will look like -> 41:10 which equals 4.10's... You divide the smaller number into the larger number. Your's will be a different ratio since you will probably have 3.08's or 2.73's.....
    You will be fine with 33's with 3.08's... I ran 35's with them for about 4 years and it wasn't too bad.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
