how do I lower t-case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblazer433, Aug 1, 2002.
  1. bigblazer433
    bigblazer433 Registered Member
    Jul 29, 2002
    38
    El Reno Oklahoma
    How do I lower the t-case on my 87 blazer /forums/images/icons/confused.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I think you can use longer bolts and 1" square tubing as a spacer.....
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Just move your current spacer from the bottom of the cross member to the top! Worked great for me. /forums/images/icons/grin.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The cheap and quick tip is to use the spacers that are up on top of the framerail and move them down between the frame and the crossmember. Use the same bolts.
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    yeap like they said just use the current stock spacers just move them between the frame and the tranny mount.
    if they are missing you can order a Howlin Off Road drop kit /forums/images/icons/wink.gif
