How do I measure for shocks?
Discussion in 'The Garage' started by BlueOx, Aug 6, 2004.
  1. BlueOx
    BlueOx 1/2 ton status
    Aug 6, 2000
    239
    Houston, Tx
    I am about to weld some shock mounts on the 14 bolt and need to know how to pick the right shock.
    Any ideas?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    The best way is to flex the rig out to see how much travel you need. then build the mounts from there.
    Bubba had a link to an offroad prerunner site where they showed a way of doing it where you flex the rig out. take the shock on the drooped side and extend the shock all the way out and make a sweep across the frame area to make a mounting point arc. then compress the spring and the shock and make the same sweep. the lines will only cross in one point. thats where the mount needs to be.
    Thats how I'm doing my fronts.
    if not you could also go by the autozone gabriels (that doesn't look right?) or anything like a rnacho 5012,9012 or a Doestech 8304 and just mount them at half stroke and call it good.(it's good for close)
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Try this one. It came from Bubba's post
    Shock tech
