how do i open my hood. ***update***
Discussion in 'The Garage' started by shaun, Aug 24, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Took my hood off yesterday to pull my engine. Then put it back on and closed it. Now I cant get it off. It seems the cable to pop it is disconnected wtf. I cant remove the grill w/o popping the hood. I have already removed the radiator and ac condensor but all I can access is the lever to open it once it is popped. And I cant fit my hands or anything between the hood and radiator support. So is my only choice to undo the bolts holding the hood on and to lift up on the back till i can try and reach the cable. Wont this crease my hood or break my grill??? /forums/images/graemlins/doah.gif /forums/images/graemlins/dunno.gif
  2. semper-k-five
    semper-k-five 1/2 ton status
    Aug 16, 2004
    326
    Tulsa, OK
    Re: how do i open my hood.
    do you feel any tension on the hood release when you try pulling it??
  3. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Are you sure it's disconnected? Sometimes mine won't open when i pull the release... and it needs the "fonzarelli bump" to jar it loose so that it will pop up. A good soaking with wd-40 usually makes that go away for a while.
    If the cable is not working at all, you'll need to get something in there and manually move it. Try something long enough to reach the cable, (like a pair of long needle nose pliers) and then pull in the direction (should be drivers side) that the cable normally goes, and see if it will release. twisting works, but can be damaging if too much twisting is done... normally when I do it it's on some wrecked car, so it does not matter.
  4. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Try using the "Bump" method. Depending on the day and the truck's attitude towards me I have to try variations. Lately the best is right forearm across the center of the hood just in front of the hood ornament. Sometimes takes several tries to get it. If the hood won't release just lock it down and pull the cable release again. Seems the pin in the hood itself is worn out from years of use so the tension on the hood is not like it used to be. Good luck. /forums/images/graemlins/thumb.gif
  5. shaun
    Apr 22, 2003
    745
    It isnt the classic chevy hood problem. There is no tension on my cable.
  6. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    you might try a wide crowbar and wrap it with a towel adn try to pry it up. i lost tension i my cable one time and that got it to release so i could move the latch. now i have to give it the left right left combo to pop it up.
  7. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif
  8. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    the clip on my buddys 82, used wooden weages to open the hood a 1/2 inch and the used a socket to undo the latch to the mount.
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Make an 'L' shaped tool out of your favorite sturdy piece of metal. Make it 6" by 6". What you want to do is slide it underneath the hood and push on the mechanism that releases the hood. It's near the bottom of the latch that you want to push on, where the cable is suppose to attach to.
  10. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    The CHEVY LOVE TAP /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yep, exactly. There are two bolts on the front of the latch that can be un-done and it will release.
    I always have to wiggle the release, or give it the, "Chevy love tap" to get mine to open too.
    Soon once the body is completely trashed I think I'm going to have to pin my hood. It's not going to be long with the way my truck's panels have been going before there's no way in hell the hood is going to open and close correctly.
  12. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Yeah my 86 needs the bump to get the hood open. And that problem isn't exclusive to chevy either. Our 78 furd needs a good whack on the hood to pop it open as well.
  13. shaun
    Apr 22, 2003
    745
    Re: how do i open my hood. ***update problem solved***
    I got it. I undid the bolts for the rear of the hood (right in front of the windshield) leaving the hinge bolts on. The hinges then pushed mt hood up like 16 - 18 inches in the back (like a giant cowl) I then got a big screwdriver and sat in my engine bay (I have no engine, tranny, and t case) and was able to push the latch over to pop the hood. That was fun.
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,069
    479
    Grand Rapids area
    Yeah, no engine makes that job much easier. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
