How do i put a front bench on my K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by drkyello, Aug 22, 2001.
  1. drkyello
    drkyello Newbie
    Aug 21, 2001
    New to K5s and I wanted to put a front bench on my 78 K5 and any tip would help. Is there a fullsize truck i can take it from that i don't have to change? and one that fold down to give access to the rear seat too like a split bench. Thanks.
  2. ironmikek5
    ironmikek5 1/2 ton status
    May 31, 2001
    145
    Massachusetts
    You should be able to mount a split bench from any similar sized Chevy/GMC truck.
    <font color=red>"Oil? That's not my oil...that was there before" </font color=red>[​IMG]
  3. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I will be getting aftermarket seats for Jedi Mind Trick from the following company <a target="_blank" href=http://www.salesco.com>www.salesco.com</a>
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>http://coloradok5.com/gallery/Jeffs-Stuff</a>
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Let me know once you get this done. I am interested in going with a bench in the front of mine, but can't find ANYONE that has done this. I want to make sure I will still have "easy" access to the rear for the kids.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Is it a bad thing when my reality check bounces?
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    i think either depdog or grim did this with an '88 to '98 chevy 60/40 split bench out of an extended cab pickup. you'd have to make a custom mounting bracket to get it to the right height, but the seat would slide forward and allow rear access. I just picked one up for $20 but didn't have the truck with me. Going to get it mid september and that's what's going in my blazer.
    Sherman, Tx
    <font color=red>Come Awn yall...Let's go to LUCHENBACH, TEXAS!!!
    </font color=red>
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    use the mounts from a bubon and then you can put any seat in that will fit the burbon. it is easier to do it that way or a full size truck. try to use the same year. makes it even easier.
    i would love to do the same, but i have never seen a bench with 5 points.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I'm not doing a bench up front, I'm doing a 40/20/40 setup... they also have a flip rail for the passengers side seat's so access to the rear won't be a problem...
    go check out their web page, and check these out. they have a TON of seats! you can find a setup to do about anything you want to...
  8. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    That's actually exactly what I want, a 40/20/40. And they have all the necessary brackets to bolt it right in with a flip up? I am not always that good at fabricating my own stuff.
    Brian
  9. drkyello
    drkyello Newbie
    Aug 21, 2001
    thanks for all the tips guys
