How do i put fluid in rearend
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89K5mudder, May 2, 2003.
  1. 89K5mudder
    89K5mudder Registered Member
    Apr 18, 2003
    20
    Random Lake, Wisconsin (Near Sheboygan)
    I just replaced the rear differential cover on my 89 blazer because it was leeking bad do to rust. How do i fill the rearend up with fluid and how much do i put in. What kind of fluid do you all use in your rearends/
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Fill the cover up with it face up on the ground, then quickly slap it on the housing, trying not to lose any of the fluid. /forums/images/graemlins/wink.gif
    OK, seriously, there is a fill hole on one side of the housing, in front of the axle tubes. Fill it until the fluid runs out. Use regular gear oil 85w-90 or so.</font>
  3. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    [/ QUOTE ] hehehehehehehehehe!!!!!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    FYI, the best way to take the plug out is to use a 3/8 ratchet with an extension. It fits perfectly......
    Another thing to consider for next time you swap out the rear fluid is to drain it and then use som BrakeKleen to wash out all the leftover gunk and residue. I use a full can per diff. Make sure you use a rag and scoop out any leftover sludge from the bottom of the diff and allow it to fully dry out before replacing the cover and adding fresh gear oil.
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Well, I usually use 80w90 Valvoline or 90w140 Valvoline Semi-Synthetic. Otherwise I use the Slick 50 brand 80w90. They all cost ~$5/quart. It should take ~5 pints. Therefore you need to buy 3 quarts of oil.
    There are two ways to fill it. You can go get a chainfall and lift the truck up about 6' in the back and fill with gear oil. Reinstall cover.
    The easy way is to go get yourself a 3/8" ratchet with a 3" long 3/8" extension on it. You go find a plug that happens to be on the passenger side in front of the axle tube just above the centerline of the axle tube. You may have to clean the squaredrive hole in the plug with a small screwdriver first.
  6. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    don't they have all kinds of pictures of this online (don't ask me where... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. amm888
    Jul 20, 2002
    309
    Woodland Hills, CA
    i've also heard that some people fill while there truck is on a bit of an incline so that you can get more fluid in there...
  8. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Re: How do i put fluid in rearend (and a new question)
    That's actually a bad idea. They design the fluid height so that you have the ideal amount of oil. Too much and it'll foam and overheat. too little and it won't get down the tubes to the bearings.
    If you look inside an axle you can see that the ring gear actually flings oil around, through the top of the case, in front of the pinion bearings, and then it drains through the bearings. If you look at a rear ten bolt cover it's designed to let oil drip down those little holes and go down the tubes.
    Speaking of such, has anyone used a front ten bolt cover on the back and not had lubrication problems? As you all probably know the front cover is at least twice as thick.
  9. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    I had heard someone who filled ziploc baggies with the proper amount of gear oil, shoved them in, bolted the cover up, then when the truck went to move, the ring gear shredded the ziplocs and released all the oil. Never tried it, but hey, its an idea! He never had any problems with it, but i'm not brave enough to do that in my truck!
  10. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yeah, it's an idea alright. An idea that I would normally describe with some swear words...but those aren't allowed here. That guy is nucking futs. /forums/images/graemlins/shocked.gif
  11. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    My Grandpa had a S10 Blazer that some grease monkey left their shop rag in. The rear end didn't last long with a rag running through the gears periodically.
    That idea might work... but only in emergency situations. It sure would suck to get melted plastic in the bearings...
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    They did this on junkyard wars one time.
  13. gumneck
    gumneck Registered Member
    Feb 6, 2003
    89
    VA
    Here's my 1/4 cent worth. When I get time to drill my broken hold down bolt out so I can replace the axle shaft oil seal. I am going to squirt some of the new 85w90 right onto the gears and such before I put the rear cover back on. Its probably not necessary but I am anal like that. That way there is no doubt that all my parts will be lubed and ready. Which leads me to a question.
    Would most folks replace both axle shaft oil seals at this time? One I feel positive is bad. The other seems ok as there doesn't appear to be any leaking going on. It would be a shame to have to do this job again in a year wouldn't you say.
    Tks,
    Tom
  14. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    yeppers, there is a lil plug thing on the side/front of the diff... prolly on the passanger side. 3/8" ratchet it off and you're golden... pour in fluid until its level with the bottom of the hole.
    good advice from others on cleaning a diff too... lots and lots of spray cleaner (brake etc) then use some kinda rag or something to wipe out the bottom of the diff... get those last few big chunks.
    j
  15. 89K5mudder
    Apr 18, 2003
    20
    I didnt see a plug. The only thing that i saw was the plug that the vent tube was hooked up to, is that where i fill? I will have to look again. I need to do this asap.
  16. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    It's not a hex head bolt, it's a critter that looks like the back end of a 3/8" socket. It's on the passenger side of the diff. close to the input.
  17. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    So, it's a little after 11pm and I have a Communications exam at 7:45am the next morning. I get an email saying somebody still can't find the damn plug on a rear ten bolt even though I practically drew a map.
    So, I wander outside, flip my axle over in the barn (I've had it sitting on its perches while I convert it to disk), and take a picture.
    Sorry, but I had to harass you about not finding the plug. I couldn't help myself. /forums/images/graemlins/grin.gif
  18. 89K5mudder
    Apr 18, 2003
    20
    I found the plug but thanks for the picture anyways.
  19. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    YUP I havent seen to many of them but that time they were usen a K5 BLAZER so I watched it /forums/images/graemlins/thumb.gif
