How do i remove my glove box latch?
Discussion in 'The Garage' started by deek, Apr 28, 2004.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    The knob broke off on the old one, so its off & gone but i have another one in another truck but I don't know how to remove it. Its just a regular turn knob, theres no lock. /forums/images/graemlins/k5.gif
  2. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I'd like to know that same question.
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Is there a hole in the center of the knob???
    Try plushing a straight pick into it..then turn the knob..
    It should fall apart..
  4. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    Thanks for helping, but it dosn't seem to be working for me. has this method worked for you before?
    Damn! the sad thing is it's just a glovebox, anything else would be taken care of... /forums/images/graemlins/weld.gif... /forums/images/graemlins/grind.gif... /forums/images/graemlins/hack.gif
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    The poor mans being defeated by a glove box latch /forums/images/graemlins/frown.gif What's the world coming down too /forums/images/graemlins/doah.gif
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    There are 2 spring loaded tabs inside that push out radially on the housing. I use a paper clip to reach into the hole. You have to work it around till you can get it through the holes in the tabs, which in turn pull them clear of the groove in the housing. I don't remember the exact sequence, but seems like it is setting neutral, work the wire in, and twist. Or maybe not. I just fiddle with it and then it comes out. I always forget the details before it comes up again.
  7. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    I set the glove box down for a second just to take a break, & I swear i can hear it taunting me, just laughing away. /forums/images/graemlins/yikes.gif
    Does this make me any less of a man? /forums/images/graemlins/confused.gif
  8. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    thanks for the help everyone, I finaly got it, only took an extra day /forums/images/graemlins/doah.gif
  9. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    So how did you do it?
  10. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    When I popped off my 1985 K30 glove box knob off, I found that all it has is a sharp inside edge on the chrome knob, which just grabs a sharp outer edge on the lock housing. The way I got it off was just to pry the outer edge on the chrome dress knob, with a large wide flat blade screw driver (use some kind of small shop towel under the blade of the driver to protect the paint on the glove box), and it popped right off. When I looked at the lock with the knob off, there was no small hole at all with a spring depress in it. It was just flat metal behind it. To install the chrome knob cover, I just pushed it back on, and the sharp inner and outer edges just locked back together.
  11. rocknutah
    rocknutah Registered Member
    Feb 7, 2005
    61
    slc utah
    On the latch side of the box there is a slot toward the door, there is a retainer tumbler at that slot, depress tumbler with a paper clip or small pick, while pulling on the cylinder from the front side. The cylinder should slide out of the case. Now the retainer nut is visible, you can modify a bolt with a grinder to use as a tool to tighten or remove the nut from the lock case.
