How do I remove the bottom race on a Front D60?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Jan 19, 2003.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'm still in the process of installing my front Dana 60. I'm rebuilding everything I can. I removed the bottom caps and and found that the bearings and races need replacing. I tried pulling the races out but they seem to be pressed in. Anybody know how to do it without having to take the axle to a hydraulic press or something like that? Is it worth replacing since it is a very low speed application? The races are slightly pitted as well as a few of the rollers in the bearings. One bearing has more play than the other.
    I'm trying to do everything within reach to prevent death wobble before I even get it. That's the only reason I want to replace them.
    FYI: A D44 or front 10bolt uses ball joints both up and down on each side, a D60 uses a kingpin on top and a tapered bearing on the bottom. This is the bearing I'm talking about.
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    use a brass drift and try to beat them out. it's a big PITA
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
  4. Blazer79
    1,816
    I can't read that thread. Access is denied. /forums/images/graemlins/frown.gif
  5. Blazer79
    1,816
    I tried today but gave up. I don't have a brass drift, so I was trying with a screwdriver /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you have to knock the freeze plug out and tap the bearing out from the top side.
    I have some notes from another site but cannot seem to locate them on my HDD.
    the size for a replacement freeze plug is in them....
    will look more tomorrow
  7. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I posted it in the bloody knuckle......thats why you cant see it...sorry
