How do I remove this u-joint from the shaft?
Discussion in 'The Garage' started by BLUESMAN, Oct 31, 2002.
  1. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    I have a front driveshaft off my 203 case and I can't get the u-joint out.It looks like there are some plastic pins that hold the u-joint to the CV(?).Can I drill them out and then what do I replace them with??Thanks Mike
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Those "plastic pins" are actually plastic that was forced in there hot to create a lock ring. To get it out you need to heat the yoke with a small torch to melt the plastic out. When it gets hot enough it will start oozing out of the hole. Once you have done this you can press the u-joint out.
    Mike
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Mr Chevy's right..... Good way to stink up the garage /forums/images/graemlins/tongue.gif...
    Marv
  4. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    What do you use to hold the u-joint in after the plastic is removed ?
    Dan...
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The new u-joint should come with a spring clip that fits in a groove on the yoke. /forums/images/graemlins/cool.gif It doesn't take a tremendous amount of heat to remove the factory injected plastic. A propane torch will do the job just fine. You just want enough heat for the plastic to start oozing out of the hole. Then press the joint apart while it's still hot. /forums/images/graemlins/thumb.gif
  6. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    "press the joint out"..... what they mean is, get a BFH and an impact socket about the same diameter as the joint and start a wacken.... or at least that's the method i use as I don't have a press in my garage. /forums/images/graemlins/wink.gif
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The BFH method works, but I have a small hydraulic press in the garage, as well as the beefy C-clamp type of u-joint and ball joint press from Harbor Freight. Either one makes the process much more elegant. /forums/images/graemlins/thumb.gif
  8. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    One other comment, I had to do this job on my S10 and I metled out the plastic like the guys said but it still wouldn't come out! so I use my cutting torch to get it out. well while torching the joint cought on fire! Ohhhh look at that there are TWO liltle holes for the plastic to ooozzzz out of, no wonder why I couldn't get the dang thing out!
    So in other words make sure you melt out both injection holes, one on each side of the cap!
  9. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    You will want to pick up a U-joint and ball joint press because it also helps you put it all back together. The hammer method makes it hard to keep the bearings in while installing the new u-joints. A C-clamp has that little swivel thing on the end that makes it hard to keep everything in-line. Check out Harbor Freight:
    http://www.harborfreightusa.com/Displayitem_retail.taf?itemnumber=38335
    Good luck.
  10. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    when we did my U-joints in my truck since they were grateing, and the front wheel joints had lost all of the needle bearings and grease /forums/images/graemlins/crazy.gif, we used our vice and some sockets, works great /forums/images/graemlins/thumb.gif, i use the vice as my press in some cases. but just remember to take that clip out, i heard about one guy who forgot to and put extrimely high pressure on a press to press out the u-joint, and bent somthing /forums/images/graemlins/crazy.gif, good luck.
  11. BLUESMAN
    Oct 3, 2001
    951
    Thanks for the tip about the torch!!I was going to drill them out,but the torch sounds better.When I remove the u-joint are there going to be grooves for the new u joint to clip into?I've replaced alot of u joints,but this one had me wondering!!Socket and a BF Hammer always worked for me.
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a cutting torch is way hotter then you need...
    go with plumbers propane torch
  13. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Harry - did you get the 3 in 1 service kit from Harbor Freight? I've seen different ones in their catalog and don't know which one has the right sized parts.
  14. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    i use the socket method for removeing, i use the vice for installing, somtimes they pop in there good too., and install yur lock rings, inner or outer, i had to install a new u-joint on the rear of my shaft on my truck to be compatable with my new 12 bolt, i just hammered the old one out, pressed the new one in, of corse you can hammer the new one in there too, but i prefer the press\vice method for installation. /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  15. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Howdy Pam! Yes, I bought the 3-in-1 kit that CookinWithGas provided a link to. They have another kit that looks like it would bend pretty easy. The kit listed above is majorly heavy duty. It's often on sale for much less than the $39.99 price. /forums/images/graemlins/cool.gif
  16. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    I neat u-joint tool from northern tools. Its called the tiger tool and make's short work on u-joints.
    Colin
  17. Skigirl
    Apr 2, 2001
    2,563
    Thanks Harry. (Howdy to you too!) /forums/images/graemlins/grin.gif
