How do I replace my fuel filter?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyhs, Jan 16, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I have a '90 Suburban with a 350ci. I think I have the stock fuel filter on it (I just bought it in Nov). Is it a pressurized system. What do I need to know before I atemped this?
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    Just that you'll get gas everywhere when you disconnect the filter. It helps to put rags underneath the filter/frame rail to help catch some of the gas. Takes about 15 mins to do.
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    It's much easier than a F*rd, you actually get to use REAL tools, rather than little plastic spring retractors...
    Passenger side, inside of frame rail...in case you weren't aware and make sure to put in in correctly, as they are directional.
    Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/album/26246038MbQsYWKcbo>U.S.S. Nimitz II</a>
  4. chvyhs
    Feb 12, 2001
    1,469
    So I just take the old one off, put the new one on, and go?
    The reason I'm doing this is to bring back some performance. I did the air filter, oil and oil filter, next I want to do the fuel filter. After the fuel filter I plan on doing the plugs, wires, cap, rotor, and trans filter. Can you think of anything else that might bring back some power?
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Pay a little bit extra and get performance wires, cap, etc. Open up the gap on the spark plugs a few thousandths. Put some fuel injecter cleaner in the tank.
    My Chevy isn't broken, its just out of gas.
  6. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    Correct...old off, new on and go. It's pressurized, so have some old rags on hand when you pull the lines.
    Sounds like you have it pretty much covered. Might want to also change out your coolant, make sure your thermostat is working properly and use a good fuel injector cleaner in the tank (after the new filter).
