How do I replace my motor mounts ?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by opfor2, Feb 16, 2003.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I would like to change my motor mounts from stock to Poly's on my 1990 Blazer. My question is HOW ???? Can I just jack up the motor with a floor jack or do I need to pull it from the top ? and how hard is it ? It looks pretty straight forward but...
    thanks
    Dan...
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    easy as it looks, take out the main bolt(s), then jack up the motor, un bolt the lowers, and bolt in the new ones, lower it back in place na dput the main bolts back in
  3. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    OK, How would you jack the motor up without damaging it ? I guess what I'm asking is where do you place the floor jack ?
    Dan....
  4. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    Place a block of wood under the oil pan to disperse the weight, and jack carefully.
  5. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    Thank you,, Thats what I was thinking but I wasn't 100% sure.
    Dan....
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    just do it carefully, careful with the pan bottom
    good luck /forums/images/graemlins/laugh.gif
