How do I replace the coil in my 91 A/C compressor?
Discussion in 'The Garage' started by afroman006, Jul 10, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I've had a problem with the A/c fuse blowing in my burban and two people have suggested replacing some coil in the pump. How hard is this to do? I looked in both my Haynes and Chiltons manuals and neither have any info on this. How much would a new coil cost and can I install it myself? Will I need any special tools? What do I need to know before I do it? A factory re-man one is like $130 at Autozone so do yall think the work of replacing the coil is worht that much money? Thx
  2. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    The coil is behind the pulley, you sometimes need a puller to get the pulley off. Which means removing the compressor from the motor...
  3. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    If you have the correct tools all you have to do is remove the top portion of the fan shroud to do it....
    DW
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I am not sure why a bad coil would cause the a/c fuse to blow. The function of the coil on the a/c condensor is to engage the clutch so the compressor will turn. If this is the coil you are wanting to replace, it is replacable without removing the compressor. It requires a a/c clutch puller, a pair of snap ring plires, and a deep 7/16" or 1/2" socket. You will have to remove the top half of the fan shroud to have adequate working room.
    From what you are saying, I think you should invest in a little more diagnostics before replacing parts.
