How do I "reseal" my 208 and 700 together?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Apr 1, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    How do I \"reseal\" my 208 and 700 together?
    Okay, I believe from what I have heard from people is that one source of my tranny fluid leak could be from the seal between the tcase (NP208) and the tranny (700R4). One guy told me to "slide the tcase back a bit and put some silicone in the joint". I have never pulled or worked on my tcase, so I don't know what he is talking about.
    Is it possible to open up the union of these two enough to get some gasket sealant in there without dropping the tcase? Or do I need to drop it to do this? Is this a job that can be done by one person?
  2. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Re: How do I \"reseal\" my 208 and 700 together?
    Its not hard, but I would slide them apart enough to replace the rubber "o" ring at the adapter, between the 700r and the adapter itself, clean the milled sufaces well then silicone them back together. I would say 1 six pack and a Saturday afternoon, if a friend helps 2 six packs and a Saturday afternoon. Its has a 3-4 wrench rating LOL
    Good Luck
    White Knight
  3. lsak5
    lsak5 Registered Member
    Mar 19, 2002
    26
    Marietta, GA
    Yep, gotta do the same. I've got a couple sheets of gasket meterial and was thinking of pulling the two completely apart. But I think the advise given will work. Might try to cut some O ring style gakets and silicone the hell out of it. Good Luck.
