how do I set the timing...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JoshA, Sep 27, 2002.
  1. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    the subject says it all. I have a timing light and I know how to use it, but what I need to know is what should the timing be set at.
    I have a mostly stock 350 with hei, and I live at about 4000ft (I think). I think that I'm supposed to disconnect the vacuum line to the distributor but I'm not sure.
    any help is appreciated.
    BTW the problem I'm trying to fix is excessive exhaust smell. it smells very bad in the cab, like the gas isn't being burnt all the way. if anyone has any suggestions about this problem I'd love to hear them.
    thanks
  2. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    Have you checked your mixture in your carb. How does the motor run rough, smooth, slugish? A little more info might help diagnose it better. BTW, do you have a timing tab on your balancer? You should just time it off of that. Just find out what the marks correspond with from a shop manual etc.
  3. yellowmoon
    yellowmoon Registered Member
    Dec 30, 2001
    94
    Modesto Ca.
    I just downloaded some great instructions about a month ago on how to time your vehicle. It went through the base, centrifical and vacuum timing. Really great, and I did it and the truck works great. I will find the addy and post it.
  4. JoshA
    Apr 9, 2001
    104
    slc,ut
    sounds great, I'd love to see the instructions.
