How do I ship a crankshaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jun 8, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    i'm selling one, and it sounds like its going to be going a ways...what do I need to pack it in?
    90K5
  2. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    Why don't you place the crank in a big plastic bag and then put it it box filled with liquid spray foam. Then wait unitl its dried and then fill it up again so it would be completly sealed in foam. just a thoght.
    Craig
  3. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    Where i work we get tons of parts that way but it works really well is a bitch to up pack but hey your not un packing it if it where me that s what id do try and make the bag loose so that when you fill it up it will get in and around tha crank
    AJ
    Soon to wheelin spot near you
    Project Harvey[​IMG]
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    You could take a piece of 1/2" plywood and screw a few pieces of 1x6 board onto it edgewise, to make a sort of cradle for the crank. One for each end and at least one in the middle of the crank. Cut a semicircle into the 1x6's for the crank journals and pad them with duct tape so the journals don't get scuffed. Bag the crank before placing it in this. Should only add a few pounds to ship weight.
    <font color=red>Click those banners and help support CK5!!<font color=black>
    [​IMG] Semper Maintenance!
    <A target="_blank" HREF=http://www.jarheadsk5.coloradok5.com>http://www.jarheadsk5.coloradok5.com</A>
