How do i stop my motor from dieseling after i shut it off?
Discussion in 'The Garage' started by fordeater, Apr 14, 2004.
  1. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    About every other time i turn my rig off, it diesels. I don't know how to fix it. I'm running a 350 with a 600cfm edelbrock carb. Is it carb related or timing related? /forums/images/graemlins/1zhelp.gif
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Could be either one, brother. Too much timing or too rich of a mixture can cause run-on. You should also make sure that your advance weights and rotor aren't sticky. Pop off the distributor cap and make sure everything is kosher under there...
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    In the mean time leave it in gear when you shut it off so it can't Diesel, then put it in park.
  4. Can Can
    15,552
    136
    BTW, fill out your profile a little more completely, my friend. For all you know one of us might live around the corner from you- don't be scared, most of us don't bite!!! /forums/images/graemlins/rotfl.gif
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I always thought that dieseling was caused from a build up of carbon deposits on the heads, and the way to cure it was to spray some cold water down the carb to break it loose. /forums/images/graemlins/dunno.gif Maybe someone can correct me if I'm wrong. /forums/images/graemlins/deal.gif
  6. v-3500
    v-3500 Registered Member
    Apr 3, 2004
    46
    Yes, SpearChucker you are correct. Spraying a fine-mist of water into the throat of the carburetor, while the engine is running, has worked successfully for me in the past; when I had an old clunker engine that I needed to last a few more miles until I rebuilt it. Another thing that should be looked into is a fuel leak in the carburetor main-body gasket. The carburetor could be continuing to feed it gas after it has been shut down.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Shut it off in gear. Check your timing and plugs to see if it's running rich or lean.
  8. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    most common problem to cause it to run on is fuel still being drawn into the motor. Check that your butterfly's are shut in the carb when the gas peddle is not depressed, when you are idling and also when shutting the motor off the carb should only be drawing fuel through the idle jets, so if the butterfly's are open even just a little then the motor will still be sucking gas and air... /forums/images/graemlins/deal.gif
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    turn idle speed down or retard the ignition timing a little bit, this is a very easy problem to correct, and is common but can damage the engine if you allow it to continue
    good luck
  10. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I rode in a friend's car one time. After we got where we were going and shut the engine off, it ran on for, no joke, 30 seconds! /forums/images/graemlins/rotfl.gif
  11. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    i used tranny fluid instead of water hold the throttle open and pour a little in. it smokes a lot but steams it out... worked great for me
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Like Limey said...use tranny fluid instead of water. I've done this literally hundreds of times on different vehicles I've owned and worked on and yes, its always fun to watch the garage and neighborhood get all smoky white. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  13. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Got ya beat. After plowing once this past winter our truck was nice and toasty. I shut it off and it dieseled so for shits and giggles I let it go...after at least a minute I got bored and let the clutch out to stop it. Thanks for the tranny fluid tip. My 86 blazer has started that dieseling crap now too.
  14. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    Mine only does it when its warm/hot outside. Whenever its cold, it won't diesel. It's pretty annoying. How much tranny fluid should i dump in?
  15. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
  16. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Don't just dump a whole bunch in. Pour in a little bit in a time. Make sure you do it outside. Lots and lots of smoke.
    I was bringin back to life an old motor in my uncles garage and I had folks stoppin thinkin there was a fire. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Be prepared to be usin two hands. One to pour and one to keep crackin the throttle.
    Good luck to y'all in the future.
    Allan
