How do I tell if my new burb has a 400 in it or a 350?
Discussion in 'The Garage' started by Topdown, Jan 29, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Its bone-ass stock, still has the heat tube from the exhaust manifold to the air-filter... the sticker on the air filter says that its a 400ci engine. However, I want to know for sure... how do I tell?
    Is do I have to check casting numbers? If so, what numbers will indicate that its a 400? Is the block color an indicator?
    -Ryan
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    What year is the Burb?
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    easist way to tell is to crawl under it,the 400's had a 3rd freeze plug on the sides, there may not be a 3rd but there is still a casting boss for it. also the balancer would be cut for balance, since the 400 is externaly balanced. /forums/images/graemlins/peace.gif
  4. Topdown
    Nov 26, 2002
    2,598
  5. Topdown
    Nov 26, 2002
    2,598
    Hmm... Thanks!
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Checking for the 3rd freeze and/or boss is a good idea, but not all 400 had the middle boss. I would still check, because if you see it, then it is a 400. If it is not there, then it still may be a 400.
    Like Jeremy said, look for the unique balancer and also check the flywheel/flexplate(if you can see it). The 400 flexplates will have a weight(s) welded to it.
    Post up the casting numbers on the back of the block and the stamped number on the block in front of the pass. side cyl. head. Someone can decifer it for you. /forums/images/graemlins/waytogo.gif
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    In addition to what Beast388 said, look for the numbers 509 cast into the block on the bottom sides..........both the 400's I ran had that feature.
    Does your 78 have original sticker under the hood on the radiator cover? /forums/images/graemlins/laugh.gif Not that it would mean what you have NOW is a 400 but might tell you if it had one factory.
  8. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    [/ QUOTE ]I have exactly what beast is talking about...I don't have three feeze plugs but it is a 400. Like BurbinOR said look for 509 as the (i think) last three digits on the block. Mine had a 6 or 7 digit number on the bellhousing next to the dist and ended with 509. I think(not sure) that I have a later 400 because of the lack of a 3rd freeze plug. Yours might be just like mine since it's a 78'. /forums/images/graemlins/waytogo.gif
  9. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    511 was also a 400...i have a casting number book...get the number at the back drivers side of the block...on the bellhousing flange just down from the drivers side head...
  10. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    I think the 511 400's were the earlier 70-73 4 bolt mains. Right?
  11. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Just look at the balancer. It will have what looks like a chunk missing from part of its perimeter. All factory 400s are externally balanced and will have this kind of balancer. I'd link to a pic but couldn't find 1. I didn't look too hard though. /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
