How do I tell if my springs are worn out?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Dec 27, 2001.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Here's the scenario - my truck is a stock 84. The ride quality seems to have deteriorated lately, but my shocks don't seem to be the culprit. I'll probably replace them in the springtime anyway...........BUT, could the problem be with my springs?
    Is there any way to tell if the springs are shot? Somebody told me that the only way to tell is to take a measurement of the distance from the ground to the fender lip, but he never told me what the measurement should be.
    Does anybody have any ideas for me?
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    It could be body mounts or something along those lines also ...
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    BUILT NOT BOUGHT
    <font color=red>MERRY CHRISTMAS</font color=red>
  3. Can Can
    15,552
    136
    The body mounts still look pretty good. I'm also planning on doing the sway bar bushings this spring as well. They're all cracked and stretched.......
  4. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I think to be on the safe side you should install some 4" TC EZ rides.[​IMG][​IMG]
    Seriously, you could take some measurments and see if the truck is sagging in the rear. Measure up to the body line at the rear and at the front. The line I'm talking about is roughly 6" or so above the rear fender lip and runs the length of the truck. Once you have some number to look at you'll see how much sag you have. Considering the truck is 18 years old the spring eye bushings are probably shot and the springs have probably lost some arch. You could use add-as-leafs to get it back to stock height and level again or you could just order some new stock springs from LMC or something.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    check to make sure the spring are not brken any where I have had boken spring before on my 84 k5. Also go to the mall and find another K5 park next to it and just look at the 2 trucks for height diffrence
    <font color=red>Let me at it I can break it</font color=red>
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    K5's are not mall running posers[​IMG] You should of said go to the local 4 wheel drive shop and park next to it...[​IMG]
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  7. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    Not only that but who's to say the K5 you park beside isn't as sagged as yours? Or the tires are a hair taller, or it has a 1" body lift? The possibilties are endless.
    Rene
  8. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    Sorry just a suggestion! Try the space between the spring and the bump stop. If the are both stock height
  9. dyeager535
    26,980
    I'm going to trust my old posts and say that the body line front to rear isn't even. I think if you measure even to the bed rail from teh line you get some height difference, and if you look at the truck from aways back, you will see that the body line slopes down the closer you get to the front of the truck.
    Then again, I still haven't replaced my sagged rear springs and one saggy front spring (bent frame? I don't think so!) so it could be optical delusions. : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  10. dyeager535
    26,980
    Crud. Forgot to add that the rocker panel pinch (the lowest part of the body) is probably a static measuring point..by that I mean that it should be level from at least the front edge of the door (where the front fender ends and the body pinch begins) to the front of the rear wheelwell. It's not going to tell you how MUCH sag, but if theres a height difference front to back (or side to side) the springs have sagged.
    Dorian
  11. Can Can
    15,552
    136
    I took a close look at how the truck sits tonight(I didn't measure anyhting because it's too dark and WAY too cold!!!BRRRR!!![​IMG]), but the rig seems to sit nice and square from all angles.
    The mention of the bumpstops made me remember something. Last time I was under the truck I noticed black circles on the springs below the bumpstops, and because I'm so friggin' clever[​IMG] I deduced that the springs were hitting the stops often enough to leave marks. I never wheel but I'm on some pretty harsh mountain roads(especially in the winter when I go ice-fishing) from time to time.
    Is THIS a sign that the springs need to be replaced?
  12. hammer
    Aug 29, 2001
    449
    Binghamton N.Y.
    What is the space between the spring pad and the bumpstop? Front and rear!
  13. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've noticed that my Rancho 5000's ride rougher in the winter time. My guess is that the oil thickens from the cold and doesn't move as well through the internal orifices. [​IMG] Maybe you're noticing something similar? BTW, the stock springs bottom fairly often, even when new. They just don't have much travel...
  14. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    Do your springs squeak? Do they look like there sitting flat? Thats whay mine looked like. I sold the truck before I could put new springs in it, but it was the springs. Good luck.
