How do I test for a bad TPS? searched but...
Discussion in 'The Garage' started by tx_sub, Nov 19, 2004.
  1. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    tried the search but gave up.
    how do i test to see if my tps is functioning properly? i'm trying to chase down my rough idle problem and all help is greatly appreciated.
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thinking.gif
  2. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    no codes. egr moves without binding, and changes idle when depressed.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Backprobe the sensor at the signal wire. It should be .5V closed, and 4.5v open.
  4. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    with the engine running? or off or ingnition in on position?
    and could it be bad and not throw a code?
  5. dyeager535
    26,982
    191
    You can test it with engine off, key on.
    It needs to be smooth too, the voltage should change as throttle position does.
  6. tx_sub
    Mar 5, 2004
    548
    Denton, TEXAS
    thanks
    but i still would like to know if it could be bad and NOT throw a code?
  7. dyeager535
    26,982
    191
    Yes, it can, since the ECM interprets TPS voltage as a percentage of throttle opening. The ECM can't tell that you aren't holding the pedal down (for instance) when it is seeing voltage that indicates WOT, if that makes any sense.
    It can be outside of the base range of voltage and I don't believe you will see any codes. Again, it comes back to the fact that the ECM doesn't really know how far your foot is depressing the pedal, if at all.
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You need to get a cheep analog (not digital) volt meter. Hook it up to the TPS and measure the resistance as you open the throttle. The analog meter will pick up "blips" that you would miss with a digital meter. It needs to be smooth.
