how do i trim my fenders?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigoltrux77, Aug 26, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    ok i saw this 79 blazer in 4wheeler mag and it had a 4" lift adn ran 38.5" TSL's. They said it had alot of fender trimming and it looked pretty sweet. Im running a 4" suspension and i would like to put 37x13-15 Boggers on it. I like the whole cat stance idea. Not too much lift but big tires. Ive never quite understood how you trim your fenders that much. Ive trimmed the corners to run my 35's but thats it. Can someone explain the proper way? And how do you get rid of that gross layered look that the sheet metal has when your done? Thanks alot guys
  2. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Get a sawzall, some torch blades w/ at least 14 tpi, and cut the sh!t out of it. When your done, weld the seam back together.
  3. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    check out my webshots page "the sub" i got a step by step in there on mine. nothing huge but they look great if i do say so myself. /forums/images/icons/grin.gif
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
  5. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    WHy even cut like that? Just unbolt and be done with it.
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    he he, i thought of that... but untill i have a lot of money and can buy tube then i have to have the fenders there to hold the hood on and the radiator support in place.
    /forums/images/icons/frown.gif
    grant
  8. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Tape them off using masking tape.I went 2" above the fender and 4" behind the fender,2" in front(to the side marker).Them get yer sawzall and carefully start cutting.You will have to cut all the way to the firewall to clear 38's.Take your time or if your can pratice on an extra fender or a buddys! /forums/images/icons/shocked.gif Hey Grant.....LOVE THAT "HAPPY FACE"!!!Mike
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    i like the happy face also... he he
    i went from zero inches below the seam to the top edge of the mearker light... but yall knew that already...
    grant
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    in my sig there are pics of how we did mine. a buddy flared them and added a lip so that i wouldn't be doing as mich self-sipping to the 39's.
    i am running a 6" (more or less) lift and the 39.5 do fins so far...
    if you are on dsl or cable, check out the spmiller.org link.
  11. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I spent an hour carefully trimming 1 front fender so it was nice and smooth and strait and stuff, but the I looked at the rest of the truck and wheeled out the torches and did the other 3 in 10 minutes!! that was on my 76. 4" lift on 40's
