How do i wire a volt guage?
Discussion in 'The Garage' started by awsomeforce, Nov 24, 2006.
  1. awsomeforce
    awsomeforce Registered Member
    Sep 20, 2006
    7
    detroit, Michigan
    i have a volt guage and an amp guage. i want to know how to exactly wire both of them since i dont know which one works. i'm really close to getting this truck done and i want to know if my electrical system is working.
    thanks,
    scott
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    An amp gauge runs between your main power and your fuse block usually.. It's a shunt style system..
    DO NOT run an ampmeter! whether it works or not.... They are notoriously inaccurate and dangerous..
    Run a voltmeter... ignition and ground is all it needs.. and lighting...
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    A shunt style ammeter is safe. The gauge is calibrated to the shunt. Only the shunt sees the charging current. It's the series-connected ammeter that presents a hazard because the full charging current runs through it. :eek1:
    IMO, the more gauges the better. :D
