how do i wire these?
Discussion in 'The Garage' started by bigbadchev84, Oct 2, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i tried the audio forum, but not much input there, i am wanting to get these fixed quick! I have a 4ohm amp and these subs that are 2ohm or 8ohm dvcs they are 10" Orion xtr3s i have them in a bandpass box and they are bridged with the +s wired together and the -s wired together they hit decent down low, but when i go to turn it up 1/2way the amp starts to cut out i have tried 3 different amps with the same thing. im sure i have them wired wrong. any ideas?
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    the rockford fosgate wiring wizard should tell you
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    got a link?
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    also, you have to know the ohm load of your subs.. test them out with a multimeter.
  6. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    If you have all the positive sides wired together, that's your problem. 4ohm voice coils, 2 each, wired in parallel and then the subs paralleled will present a 1 ohm load to your amp that is only "rated" to 4ohm. So far you're lucky your amp has only cut out and not checked out. :eek1:
    You got two choices and maybe an audio engineer will correct me but as far as I know, there's no difference. 1) put your VC's in series and the subs parallel. That will be a 4ohm load. 2) put your VC's in parallel and the subs in series. Same end result.
    Personally, I've always used option 1. Why? I dunno but my 2 12's hit like a mofo.
  7. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    X2.
  8. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    I have my subs wired in at 1 ohm and it hits hard too. But my amp is 1ohm stable. :D Go with Sky's the limits idea, it'll work. G'luck
    ~Brian
