How do I wire this to my alternator?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by divorced, Nov 4, 2004.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I bought this a long time ago and forgot how to wire it. Do I just connect the ring terminal to the post on the back of the alternator and then run a wire from there to the batteries?
  2. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    That's how mine is hooked up. I don't have a plug, but the wire runs from the post on the alternator over to the battery.
    I had a 6.2 with dual alternators, so when I swapped in the 350 I had to do new wires for the alternator.
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Yes you are correct. plug the harness into the alternator, attach the red wire with the ring terminal onto the post at the rear of the alternator, then run a large 8 or 10 gauge wire from the alternator post to the battery.
  4. divorced
    Jul 20, 2004
    5,115
    Sounds easy enough, thanks guys.
  5. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Where did you get the plug from?
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    This may sound stupid but what is that??
  7. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I second the stupid question, what is that?
  8. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    I believe it is a jumper setup for a one wire alternator hook up. /forums/images/graemlins/thinking.gif
  9. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    That is correct. That red wire is effectively a jumper to provide 12 volts to effectively "start" the alternator.
  10. sickquad
    Jul 23, 2003
    785
    Ma
    Wow, that sounds interesting, but I don't get it. Doesn't an alternator always charge when it is spinning?
  11. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    It will only charge if its hooked up to the battery
  12. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    You can kinda think of the alternator like a pump. If line pressure is the same as pump output pressure the fluid doesn't go anywhere. If line pressure drops below pump pressure, the pump starts putting out fluid. With the alternator the voltage is pressure and current is the fluid.
    Does that help?
  13. sickquad
    Jul 23, 2003
    785
    Ma
    I don't understand the "start" the alternator thing. Does the circuit turn on the alternator in some way when it needs current?
  14. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    the 12Volts to that connector provides voltage to the "field" of the alternator. The spinning alternator rotor in this magnetic field, is what causes the generation effect of the alternator. If you do not hook this 12 volts to the "field" of the alternator, all you would have is a spinning hunk of iron...
    The one wire aftermarket alternators have this built into the alternator, but most require a certain speed to "start" the alternator. Most see this when they have to rev the engine right after startup to see the alternator kick on. (ie right after startup a voltmeter will read just 12 or so volts - essentially battery power....when you rev the motor and bring the alternator up to proper speed, it will start generating, and your voltmeter should read 13-14 volts.)
    Not sure if I am gettting the point across... /forums/images/graemlins/dunno.gif
  15. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Right on the nose....exciter wire... /forums/images/graemlins/waytogo.gif /forums/images/graemlins/usaflag.gif
  16. sickquad
    Jul 23, 2003
    785
    Ma
    I get it, good explanation. Learn something new everyday.
    -Chris
  17. divorced
    Jul 20, 2004
    5,115
    I got mine from the local Napa store. I think it was around $12 or $15. I bought it to make it easy to wire the alternator in a vehicle that had no wiring, but have since scapped the vehicle. I guess I will use it on my K-20 to get rid of some extra wires. They also work good for wiring demolition derby cars.
