How do I...
Discussion in 'The Garage' started by big jimmy 91, May 10, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    wire in a switch for my head lights to be able to shut them off when I don't want them on
    I mean the way they are allways on even when the switch is turned off
    I would like to be able to turn them off when required without having to shut off the truck
    BTW it is a 91 jimmy with a 2 light system
    /forums/images/graemlins/ears.gif
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Did it come like that ? I didn't know a 91 had daytime running lights . /forums/images/graemlins/k5.gif
  3. big jimmy 91
    Feb 21, 2004
    639
    As soon as I turn the key into the on position the head lights turn on in that half power high beam mode
    It is a real pain for someone to back up into lights at night with dirty windows
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well I heard that on older vehicles with daytime running lights, you could put emergency brake on a couple clicks to turn them off. If you still have an owners manual , maybe its in there. /forums/images/graemlins/k5.gif
  5. big jimmy 91
    Feb 21, 2004
    639
    No manual , I will have to try the P B trick though , since it doesn't work anyway /forums/images/graemlins/rotfl.gif
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    1.)Find the wire that powers the headlights when you turn on the truck.
    2.)Cut the wire.
    3.)Wire in a toggle switch.
    That way you leave the toggle switch in the on position, and if you want them off you kick the switch off.
    Harley
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I personally would disconnect the radio dimmer wire from the ignition wire there at the radio. /forums/images/graemlins/histerical.gif That's the most common way you can have the lights be on all the time.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
