How do I ...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Anteak, Feb 26, 2002.
  1. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    I'm about to remove my sm465/205 from the Blazer. Can anyone list the procedure to remove and replace? Should I remove the tranny and transfer as one unit? What kind of weight am I looking at? I need to replace the front seal on the tranny, is this going to be difficult? Any help/advice is welcomed. Treat me kindly, I'm a newbie.
    73 Blazer, So. Ca.
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    With a good tranny jack you can remove them both at the same time. Rental places usualy charge about $20 to rent a jack.
    A good sized floor jack works too but when I use one of those I split the 2 to keep the thing from falling off the jack.
    Along with the front seal get a gasget for for the front bearing cover, silicone will not work.
    The gasget is also a shim and if you just use silicone it will not fit right.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. Anteak
    Nov 7, 2001
    105
    Hemet, Ca.
    Thanks for the reply. Once the crossmember is removed, do I support everything at the engine or just start working my way back. If I seperate the transfer case first, will I need to drain it. Would it be easier if both are in gear for removal/installation. Are there any drawing for the front input shaft for the tranny. Is it a simple seal replacement?
    73 Blazer So. Ca.
