how do identify gears/shaft q's
Discussion in 'The Garage' started by coptezr, May 5, 2005.
  1. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    i just got a 81 parts burb 2wd :( but it has a 14 bolt rear how do i know if its a ff or sf and what gears came stock on it i have a vin#1g8gc26wcbf120615. and i have a stock front axle can i put 3/4 ton shafts in them and do i need to change anything when i do this?
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Full floater will have a hub sticking out the side of the axle with 8 bolts holding the shaft in. Also look for the bolts around the snout of the pinion.
    VIN wont tell the gears, get the #'s off the stamped tag on the axle or pull the diff. cover and get the #'s off the ring gear.
  3. coptezr
    Jan 13, 2005
    342
    and is the full floater the way to go?
  4. AkMudr
    Dec 30, 2004
    917
    Alaska
    Absolutely.
  5. coptezr
    Jan 13, 2005
    342
    what about putting 3/4 shafts in the stock 1/2 front axle?
  6. AkMudr
    Dec 30, 2004
    917
    Alaska
    Prolly a 28 spline 10 bolt, from the shafts out everything between it and a dana 44 is interchangable except the inner shafts....stub shafts are both 19 spline. Inners on a D44 are 30 spline. First figure out what type of front axle it is.
  7. AkMudr
    Dec 30, 2004
    917
    Alaska
    theres no difference in the shafts. they are the same. difference is in the actual hub itself (1inch wider with 3/4 ton) and the lug count.
  8. coptezr
    Jan 13, 2005
    342
    then can i keep my stock front axles on there with 38's will i damage anything? can i change hubs to match the back?
  9. AkMudr
    Dec 30, 2004
    917
    Alaska
    '79 and up was 10 bolt.
  10. AkMudr
    Dec 30, 2004
    917
    Alaska
    to go 8 lug you'll have change everythin from the knuckles out.
    Damage depends on how you drive. When I go bigger than my 35's I'm puttin my d60 in.
  11. coptezr
    Jan 13, 2005
    342
    whats your messenger name on yahoo?
  12. AkMudr
    Dec 30, 2004
    917
    Alaska
    i dont have it loaded right now.
  13. coptezr
    Jan 13, 2005
    342
    the only thing i do with the truck is mud a little bit and go on trails :crazy:
  14. AkMudr
    Dec 30, 2004
    917
    Alaska
    well, Im sure our driving habits are different but so far Ive bown 3 ujoints and trashed 2 sets of axle shafts if that helps. And thats with my 35's. I'm puttin 40's on soon, bye bye 10 bolt.
