How do these radiator fittings work?
Discussion in 'The Garage' started by divorced, Dec 10, 2005.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    This is on a 1996 K1500. This fitting is leaking, and it would be cool to know how it works before I tear it apart. There is a nut that tightens the fittings. How does the fitting come out? From the inside? It looks like the fitting is leaking between the fitting and tank, not the line.
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i think you're screwed, time for a new radiator.
  3. divorced
    Jul 20, 2004
    5,115
    [going crazy]
    WHAT?
    NO!!!
    $298.99!!!
    [/going crazy]
  4. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Try and get that one repaired before buying a new one. It looks like a diesel radiator and those do run real high in price.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If it is a plastic tank it is common for the tank to crack underneath that nut like thing due to the heat from the coolant entering the radiator. You might try epoxy or JBweld on the crack to see if you can get it to seal. Chances are you need a new tank at a minimum. I know there are a few shops around me that say they can replace a plastic tank.
    Ira
  6. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    oring under the addaptor in the tank side. lots of fun to fix. time for new rad.
  7. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    youd have to take the tank off, replace the rubber seal or possibly the whole tank. you need a special tool to bend the tabs unless you can get something to work. the tanks are simple to remove and replace. there are 2 rubber seals, 1 at each fitting and a rubber seal that goes around the tank. you can fix it your self if you had the parts.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you're not shopping around enough...:doah:
  9. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    I've got a diesel radiator that's all metal from an 82 K/20 I don't need. It's a little banged up, and needs boiled out, but it didn't leak when I was using it.
