How do winches get stolen? How to prevent?
Discussion in 'The Garage' started by guido666, Nov 10, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    What are some ways you've seen people steal winches? This conversation started in this thread:
    http://coloradok5.com/forums/showthread.php?t=155074
    But I didn't want to hijack.
    I suggested welding the (or extra) nuts on the ends of the mounting bolts. Maybe even weld on the nut a tack so that you can't even get a wrench on the nut. Someone said that would void the warranty? Why? What do the bolts have to do with whether the winch works or not?
    Any other ideas? Someone suggested put angleiron over them. More?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    On my old winch bumper I welded one of the bolts so that you couldn't get a wrench on it unless you used and angle grinder to reshape the head. It was also very hard to get the winch out of the old bumper unless the bumper was off the truck so I welded 1 of the bumper bolts that went threw the frame.
    My winch was used when I got it and I didn't have a warranty. All I know is my winch never came off my truck unless I was the one taking it off.
    Harley
  3. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    welding on the bolts could weaken them... especially if you did it over and over to the same bolts. How about making some little steel "domes" or caps that covered the bolt heads... tack weld those on and call it good?
    j
  4. guido666
    Feb 16, 2005
    788
    Longmont, CO
    That was exactly what I was suggesting. I assume most thieves are not carrying serious tools. I would figure they would be reluctant to use torches because of the noise and light (especially at night), and a grinder would take power.
    Any other ideas or info about the warranty?
  5. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I don't see how welding the bolts or nuts used to mount a winch would void the warranty?!? Unless, however, you actually welded them to the winch, then I could see it. Otherwise, it seems fair game. If you are worried about that, go buy some other hardware and save what came with it for "warranty purposes."
    Kris
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I just made mine a PITA to remove. You can barely fit an open end wrench in there and only get about 7* of movement. It doesn't happen fast. If you don't do it in the right order the bolts bottom out on the skid plate. This was never by design though. Harley can attest that I have accidentally made both of my mounts theft resitant (and my stinger was almost intalation proof :doah: )
  7. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    My guess would be that welding on the mounting bolts would be a no-no from a manufacturers perspective because of liability reasons. Sure, the winch will work fine... but if some garage welder guy weakens the mounting bolts a bunch and then is doing a nasty hard pull and the bolts break and the winch flies out and kills someone... well, businesses don't like lawsuits.
    j
  8. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Anyone ever seen thieves torch off the frame rails or something else crazy like that?
  9. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    Never heard of such a thing... any theif that wants to torch junk off tends to be the guy who uses a flatbed trailer + winch to steal your entire rig... takes it to a shop and chops it up there.
    j
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yep, actually happened on the midnight shift while I was working for Warn right in the Warn parking lot. Thieves came into the parking lot, torched off the frame rails behind the spring eyes and cut everything off and took it all. The owner of the rig couldn't even drive home cause the front springs weren't hooked to anything. No one saw anything.
  11. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    wow, thats some crazy chit. Warn doesn't have cameras watching their parking lot eh? Might be a good place to "find" a winch then... lol! kidding! ;)
    j
  12. mud390
    Oct 31, 2002
    1,210
    Thats nuts!!!! I would be livid!
    Kris
  13. guido666
    Feb 16, 2005
    788
    Longmont, CO
    On the scale of things, winches aren't really THAT expensive. That's pretty ballsy! Especially because over $500 is a felony.
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah there are camera's in the parking lots, but the camera's didn't pick anything up from what I remember hearing. This was like 10 yrs ago.
  15. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I welded a piece of angle iron over the nuts. I believe it was 3/4" angle iron. You can't get a wrench on the nut, just the bolt from the top.
  16. guido666
    Feb 16, 2005
    788
    Longmont, CO
    What is it welded to? The mount/bumper?
  17. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I would think a high quality alarm would be a good idea.
  18. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    Tie a dog to the bumper!! Most people wont deal with a mean barking dog. :haha:
  19. guido666
    Feb 16, 2005
    788
    Longmont, CO
    I try to keep my truck as low-tech as possible. It still bothers me that I have a digital ignition system. Besides, I think the money could be spent making all kinds of things to make your winch steal-proof. Like a giant bada$$ skid plate up front. A couple hundred bucks will get you a lot of metal, and of course a hidden battery disconnect! :D
  20. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Secuity Bolt Locker
    This 11 Gauge welded steel bolt locker secures up to a 9/16” diameter bolt, preventing access to the head with a wrench. The bolt lock is great for securing winches, racks, mounted tools, and other bolt on items.
    The locker is secured with a double bitted 10 tumbler Tuffy lock with an exclusive cam latching design.
    [​IMG][​IMG]
