How do ya get a u-joint out?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Jul 4, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    My ujoint that goes into the rear end is bad. How do you get it out after you take those 4 little bolts off. I've hit it with a hammer and it's still not off. Tomorrow I'm gonna have to get a replacement. Which joint do I need to get for a 14bolt FF rear end with a 208 transfer case? Thanks for any help you guys can give me.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    After the bolts, you take off the straps and push it forward, into the t-case and then pull it back to remove the driveshaft, but make sure the e-brake is on first and that the wheels are chocked.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Make sure that the parking brake is set, then put the tranny in neutral. This will take the tension off of the driveline. Sometimes I've found that inserting a small pry bar between the yoke and the u-joint helps persuade them to separate. /forums/images/icons/wink.gif
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I third that about chocking the wheels!! I pried mine out forgetting to chock the wheels and watched the front tires roll toward my head.
  5. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Get a dead blow hammer, or regular hammer covered in a HEAVY rag and try to tap it off the rear diff.
    After that pull the shaft from the t-case and put it on a good work bench. Get a flathead screwdriver and pop the C clips from the two cups in the driveline yoke, then get a socket about the same size as the cup (make sure its one you don't care about) and use it and a hammer to force the u-joint in one direction until the opposite cup is loose. Pull the cup out (you might need some pliers) turn over the driveline and do the same as to the otherside then pull the now cupless u-joint out.
    Replacement is the exact opposite, just be careful not to loose any needle bearings.
    If the cups will not come out you can heat up the yoke with a PROPANE torch so that it will open up and let the cups slide out easier, just be sure not to knock it out of alignment.
