How do you break in *FRONT* gears?
Discussion in 'The Garage' started by 8_YOUR_H2, Mar 13, 2003.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Ok, I need to do the 500 mile break in for my new gears. Do you have to break in the fronts? I would have to do 500 miles on dry pavement in 4HI with drive flanges for 20 minute intervals letting the diff cool between trips, for some reason that dosent sound like fun.
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    coudlnt you just lock your front hubs and drive that like? Or does that not turn your diff gears
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Lockin' the hubs turns the gears and driveshaft, they just won't be under load...maybe you could drive on a gravel/fire road with the t-case engaged to help break 'em in?? /forums/images/graemlins/1zhelp.gif
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Just think about it this way. All trucks with 4wd come from the factory brand new don't they? Does anyone bother to break in the front when we get them? I wouldn't worry about it, but that's just my opinion.
  5. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I agree, I have put 2 new gear sets in my front, one 3.73 and one 4.10 and didn't break them in at all. Both worked great with no problems. I know this is probably not the proper way to do it, but I wasn't going to drive around all day in 4WD.
  6. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Another thought: Maybe it doesn't matter if the gears are broken in, since they won't see more than 10-15 mph...hmmm
  7. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    not sure if it's the proper way, but this is what i did. i just locked in my hubs and drove back and forth from work for about two weeks. after that i changed the gear lube and called it done.
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i think the rears are the ones to worry about as they have power 100% of thier lives and only 10-15% of the fronts lives. Or that is if you are not a trailered rig.
  9. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    They dont have to have power to them to break them in. If you have driveflanges the front will rotate 100% of the time and if you drive it in 20 minute increments and let it cool in between... After 500 miles it should be considered broke in.
  10. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Pull the rear shaft and drive it over to see my pile of parts in front wheel drive. /forums/images/graemlins/grin.gif Still haven't had time to mess w/the bender /forums/images/graemlins/mad.gif
    /forums/images/graemlins/crewcab.gif /forums/images/graemlins/burb.gif
  11. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I have been wondering where you were.... IF I get that sucker going this weekend Ill stop by!
  12. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    one would think that this would make sense, but infact it does nothing to break in the drive side of the gears. if you apply power to the pinion gear, you are applying power to the drive side of the teeth. if you apply power to the ring gear (I.E. locking the hubs and driving around in 2wd) you are going to be putting the wear on the coast side of the gears. did that make any sense? it's kinda hard to follow unles you have a diff to look at.
    -Scott
