How do you cap the ends of tubing??
Discussion in 'The Garage' started by FWP, Mar 31, 2002.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    What do you guys use to cap the ends? The torch method I have used doesn't work very good for me, I have a hard time cutting a good circle from plate/forums/images/icons/laugh.gif. What do the pro's use? Any ideas?
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    On my old bumpers we used 3/16" plate - and lots of grinder discs - There's actually a few industrial steel suppliers that carry precut slugs for the purpose too.
  4. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Damn, thanks Russ. Cool site, added it to my Fav's/forums/images/icons/smile.gif -
    Hey were you able to go out to Florence with the other Yahoos?
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Hey Jeff, yeah, that's been my problem, I wind up cutting a 1/2 "-larger than needed- kind of a circle and grinding it down. Eats up a lot of labor time...
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Tack a small piece of material to the end of the tube you want to cap. Material needs to be slightly bigger than the tube, atleast 1/2' or so. Fire up the torch or plasma cutter and cut around the the tube. Just try not to cut off the tack. If you take your time and keep a steady hand, it'll come out quite nicely, very little grinding to clean it up. I used this method on the bumper I'm working on now.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, I finally made it out. Had a great time and the K30 did better than I expected with the front open and no weight (no bed) on the locked rear. Didn't take a single bypass on Upper Ajax. Had one small hang (wasn’t even on a major obstacle /forums/images/icons/crazy.gif) but one rock placed in front of a back tire was all that was needed. Picked up some slightly concave rockers (long wheel base). Also go a little rock rash (could cover it easily with my hand) on the driver’s side of the cab right behind where the door handle would have been if Marv and I hadn’t pulled them off right before the run.
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    try freeze plugs. or knockout slugs.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Good tips :thumb:
  10. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    good post dig :thumb:lol. good tips tho
  11. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If it's only for cosmetic purposes then use a concave freeze plug.
  12. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Or hole saw droppings of the correct size.
  13. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    1.5" round bar cut offs 1/8" thick or so. Should tap right into the ID of 1.75" x .120 wall tubing.
    Rene
  14. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
  15. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    I just hammer the end flat and weld up the seam that leaves.
    With thicker pipe like schedule 80 like I used for my cage I had to heat it up with a torch red hot first.
  16. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    I'm glad someone pulled this thread out of the grave... this answers my "how to cap" question for the tube doors I'll be building :D
