how do you carpet a box?
Discussion in 'Audio' started by bad_bo_ti, Jul 6, 2004.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    its a 14x14x12 box. just curious as to a good way to carpet it. thanks, chris
  2. ryoken
    Jun 13, 2003
    29,621
    1,373
    Jersey Shore
    i've never done it, but i would suspect 3M spray adhesive or contact cement would work well.. we use contact to do carpet headliners and such in the boats... maybe a little monel stapling if need be.. whatch the lighter carpets tho, the glue can seep thru if ya go heavy... maybe someone with experience will chime in....
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    wood glue
  4. bad_bo_ti
    1,027
    OhiO
    alright what about seams how do i hide them?
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    put them on the bottom, or depending how thick the carpet is, scuff the 2 edges together so it looks like one piece.
  6. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    If you're using standard subwoofer box carpeting, 3M "Super77" or "Super90" adhesive will work well. I generally cut the carpet into the rough size I need, then spray the box and carpet (one coat each) with the adhesive and let it dry slightly. Once you press them together they won't want to come apart, so position it carefully.
    A single-edge razor can be used to trim off excess carpet on the outer corners and with a sharp blade and some practice you should be able to create tight carpet joints that are barely visible.
    Also, Brake parts cleaner is a pretty good solvent for removing excess adhesive or overspray. Just shoot a little onto a clean rag and use it to gently wipe off the excesses.... /forums/images/graemlins/thumb.gif
