How do you check alternator output with a DMM?
Discussion in 'The Garage' started by Can Can, Jul 26, 2004.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I haven't driven the K5 that much this summer and if I leave it for a week or two the battery is dead when I go to start it up. Chances are the battery is toast(it's almost 8 years old), but I thought this might be a good chance to double check the alternator output and such.
    Where do I put the leads for my multimeter to check how much juice my alternator is putting out? Anyhting else I should look for while I'm checking it?
    Also, how do I tell if the battery isn't holding charge or if there's a draw on the system somewhere?
    Thanks, brothers!!! /forums/images/graemlins/thumb.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Red lead to positive battery terminal and the black lead to negative battery terminal and you will be reading voltage that's currently in the battery, now start the truck and it will be reading what the alternator is charging at. /forums/images/graemlins/thumb.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: How do you check alternator output with a DMM? *DELETED*
    Post deleted by HarryH3
  4. Can Can
    15,552
    136
    Okay, here's some figures to consider:
    Battery after the truck was boosted and running for 5 minutes- 12.6
    Reading at the battery posts at idle- 14.3
    Reading at the battery posts with lights on and heater on full- 13.3
    I thought I might add that when the alternator was under load it was whining a little bit. Without load it sounded fine.
    So is my alternator fawked too? Or is the dying battery making the alternator work harder than it has to?
  5. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I would say the battery as well. Even if the alternator isn't 100%, it is working. You know your SOL when the voltage doesn't change between off and running. You either have a draw or the battery just can't hold a charge for long. Since the battery is so old I am leaning towards it, but on trucks like ours it could be a draw as well /forums/images/graemlins/dunno.gif
  6. diesel4me
    Jul 24, 2003
    17,540
    926
    Massachussetts
    To check for a current drain or short curcuit,remove the negative battery terminal and put the test light between the battery cable and battery terminal,if it lights up,something is drawing current from the battery.Then you have to start pulling fuses or disconnecting the wires to the suspected curcuit--once you have found the drain the light will go out.Be aware if you have a clock it may make the light flash once in a while,and your dome light will show up as a drain if the doors are open. Also,I notice on my trucks the HEI distributor will make the light barely glow,until I pull the pink BAT + wire off,I dont know if its just my trucks,but they all do it,doesnt seem to kill the battery though! /forums/images/graemlins/dunno.gif Bad diodes in the altenator can do the same thing too,allow the battery to discharge when vehicle is shut off,and still charge some,at a reduced output,like when one or two of the 3 diodes croak in the altenator. But I'd say your 8 year old battery has a lot to do with your symptoms. /forums/images/graemlins/crazy.gif
  7. Can Can
    15,552
    136
    Good info, brother. Thanks for the reply!!! /forums/images/graemlins/thumb.gif
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Another thing to remember is that an alternators purpose is not to charge a battery but to maintain the charge that is in the battery. If you have a weak or dead battery and jump start the vehicle then let the alternator try to charge the battery that is making the alternator work very hard and could easily kill the alternator.
    What does this all mean you ask? You need to charge the battery fully with a SLOW charge before starting the vehicle and trying to test anything.
    As a rule after about 3 years a battery starts to die and by 5 years is almost ready for battery heaven. I would get a new quality battery then start checking for any shorts or draws on the circuit and go from there. /forums/images/graemlins/thumb.gif
