How do you check for bad motor mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Mar 28, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    How do I check to see if my motor mounts need to be replaced?
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  2. dyeager535
    26,980
    Typically if someone sits in the truck with it running, and you have the hood open, watch the motor as that person revs it. It will tend to try and "flip over" jumping pretty healthily as it tries. Some twisting is normal of course.
    Dorian
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Have someone get in the truck, and shift between drive and reverse, and give it a little gas while holding their foot on the brake so the truck doesn't move (also set the e-brake). Watch the motor, and you will be able to see if it lifts up on one side or the other from the torque.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
